so it has the string with a little weight on the end, there are Three "positions" where you can loop the string off of the bar that hangs off the side of the tonearm. I got the manual off of VE and it says "if tracking force is to be 1.5g put the loop on the second innermost position...well it is, and I moved the sliding weight on the tonearm to what I think is 1.5g and moved the sliding counter weight till the arm doesnt float, but the string runs out before it gets to the end of the LP side. so what am I doing wrong? Also can anyone that owns this arm give me a good color photo of what on original headshell for this arm looks like? I am using a technics headshell because thats all i have. Id like to get the orig headshell for my arm. I purchased a Technics EPA 250 arm that I wanted to use, but it is defective and needs work, is there another arm I can get that owuld be of the quality of an EPA 250? that is more plentiful, so I have a better chance of getting one that works?
The turntable I am using this with is a Technics SP 15.
