Help with Refoaming Pioneer HPM-900
Yeah, these foams clearly have different measurements by 1/8" or so. The best way might be to check your CONE diameter, one of these is for a 9-1/4 cone, the other for a 9-5/8 cone. That's a big enough difference that there should be no question. I usually try to measure it a couple different times in case my tape didn't go directly over the center of the circle.
Pioneer may have changed the driver they were using at some point. ?
Thanks Lazarus Long and toxcrusadr
I measure it many times ..
Outer Diameter 293mm
Inside Diameter 270mm
Cone Diameter 235mm
so this one is the correct kit for me but i need to trim the outer a little .
https://www.ebay.com/itm/2-Pioneer-...7bef4d4:g:NYcAAOSwJH1ZJIrw&afsrc=1&rmvSB=true
Hmmm... I'm not sure if you should need to trim them at all. Maybe call the company before you order, or at least send a message through eBay. The listing itself may be incorrect.
Well , i sent him a message but he didn't reply , anyway i ordered repair kit from alixpress with cheap price it has the exact measurements .
These are a MAJOR pain to do. super brittle graphite combined with the hardest glue residue know to man.
I wish you all the luck in the world.
Yeah i have read many comments from other users regarding this matter , i will be very careful and hope everything will go smooth , Thanks :)
Another question please , what do u think about this adhesive ?
we don't have aleen's taky clue in my country our choices are limited .
No; but most any PVA glue (Elmer's or another tacky brand) will work. If you use Elmer's (or something similar that is available) it will be thinner, so not as fast drying.
Thanks woodj
U mean this one ,,
That Liquid Nails is a thick sort of caulk-like adhesive. It actually comes in a caulk tube for construction adhesive applications. It's really too thick for refoaming.
