How much Dac Do I need?
nikkofan
Good Day,
I rip CD's to a mac mini with iTunes as Apple Lossless 44.1 kHz . Currently I'm using a Schiit Modi 2. My question is, would I benefit from an upgraded dac since I'm "locked in" to the CD's restrictions?
Thanks in advance,
Please stay safe,
"nikkofan"
Not really unless you start downloading some DSD files. The Schiit Modi 2 will process lossless files up to 24 bit / 192 hHz.
You aren't locked in to the CD rip specification. I'd start looking around for some higher resolution lossless files you can add to your library. I believe iTunes will process other file codecs such as FLAC. You will want to verify that for yourself of course.
I don't bother with DAC's that play anything but redbook as I've found that the quality of the DAC itself makes a far bigger difference than going to DSD. The Abbas Audio range of DAC's from the Ukraine offer superlative performance.
