muovimies
I recently came upon a Ray Anderson's What Because on vinyl. Running time for the whole album is just 3 seconds short of 56 minutes. The sides are pretty evenly spaced, about 27.45 for side A and 28.15 for side B. I wasn't expecting much for sound quality because of the long sides, but it's remarkable for such long cuts. Bass is deep and overall dynamics are good, though overall volume is just a tad down.
What's interesting is despite the extremely long running time, Side A has over an inch of run out area from the end of the last track to the record label. Side B runs a bit closer to label, but still leaves a lot of space. This is an original Swiss pressing made by Turicaphon AG, no idea who's responsible, but mastering is credited to Bob Ludwig on the record sleeve.
I've found usually anything close to 25 minutes per side and you're basically doomed especially towards the end of side, especially when buying used - usually some previous owner has carved the inner grooves with their bad/worn/incorrectly set up stylus, even if your equipment could handle it. Not so with this one. I laud whoever is responsible for great work. It also raises the question why more discs weren't pressed like this, it seems to me whatever the tradeoffs of spacing the grooves a bit tighter (volume loss mainly I suppose) would seem worth it as opposed to running very close to the label. I wonder is consumer perception has been part of it - "they left half the disc unused, I want my money's worth!"?
