canuckaudiog
On a quest for high fidelity
tl;dr version: Replacing the original B110s in my IMF Professional Monitors with new Falcon FB110s resulted in a dramatic improvement. So much so, I am now going to be recommending and replacing *all* B110s I run across in these speakers if possible. However, I think it's wise to replace only the mids, and other drivers if you can afford it, since mids cover the majority of what you hear. This has led me to believe that other vintage speakers are potentially suffering from similar issues, and likely there are a lot of vintage speakers out there that are no longer performing to their original specs, even after you refoam the drivers and replace the capacitors. Does this mean you should stop buying vintage speakers - no, many still sound great - but it is something to keep in mind since some speakers can have the drivers restored (such as Altecs, JBLs) and it can have a significant impact on how close to their original performance they can realize.
I acquired a pair of IMF Professional Monitors about a month or so ago. One thing I have always wanted to explore with these speakers is replacing the drivers with the newly made Falcon Acoustics drivers (the FB110 and FB139) because of a comment Jerry Bloomfield (the owner of Falcon Acoustics) made about KEF B110s. He had found that every pair he measured were out of spec, even a NOS pair. This would suggest that these drivers suffer from age-related issues, and also means that like replacing capacitors, to bring a speaker back to its former glory, these drivers should also be replaced.
Thankfully, because Jerry Bloomfield is such a gem and has made it possible to reproduce the B110 to exacting specs, this is now something that can be done with speakers that use this driver. In addition, the T27 and B139 have also been reproduced under the same conditions. There are a great number of speakers that use these drivers, so though it is expensive, it's something worth considering since it is available.
About two weeks ago my wife and I were sitting down for coffee and discussing future plans, and the topic of the IMFs came up. I had suggested that as far as restoring them goes, a worthwhile investment is to replace the B110s with Falcon FB110s. We were deciding whether to buy a new amplifier (to replace an A/V receiver we were using as a stopgap) or if we should invest in a better phono amplifier, or something else. I felt the drivers would bring about the greatest improvement. Also, for those wondering, my wife takes an interest in the stereo because the IMFs are hers - she was the one who originally suggested we buy them (it's part of why I married her ;-) ). We spend many evenings together playing cards and spinning vinyl on her IMFs so improving their quality and longevity is an interest for both of us.
Anyhow, I ordered the FB110s a couple of weeks ago and they arrived this past Friday. I wasted no time at all and installed them right away. To begin with, I installed one driver and compared it against the original B110. I always do this with these kinds of restorations because it's important to know if there is actually a difference or not, and if so, is it an improvement? I played a mono signal through the speakers and listened to one against the other. The difference between them was so great, that I had to double check my wiring to see if I had futzed something up. After confirming the wiring was correct, it left me with the conclusion that the new FB110 is far better. It sounded much lighter, clearer, and more natural than the original. I cannot understate the improvement here - the difference was astonishing.
Once I had confirmed the new FB110 was better, I went ahead and installed the second one. My wife and I spent the good part of that evening going through our music collection and listening to music, as if it were anew. We were both taken back by how much better the IMFs now sound. Everything I have read about the B110, how it is a vocal star, how it conveys midrange information so naturally, became apparent and true. A murkiness that resided in the midrange is completely gone now, and left is this beautiful, bell-like clarity with beautiful tone and character. In the 7 years of doing this I have never heard IMFs nor the B110 sound like this. The clarity in the midrange and overall sound depth has been taken up several notches. I still cannot believe what I am hearing!
This has left me with some conclusions, some that have changed my way of thinking around vintage speakers.
1. Drivers do age. I don't know exactly what it is, but my guess is it is the suspension that becomes hard with time and constricts the movement of the driver, lowering its overall sensitivity and frequency response. This is akin to replacing the ferro fluid in a Kef T33. Perhaps the magnet loses sensitivity over the years (ala Altec AlNiCo). Obviously as every driver has a different design and uses different materials, this varies from driver to driver.
2. The KEF B110 is a driver that suffers from age-related issues, and does benefit from being replaced with the Falcon FB110. Mine were from 1972, making them 47 years old, and I imagine the older they are, the greater the benefit realized. How old they need to be to be far enough out of spec to warrant replacing is not something I know of, but based on Jerry's comments, it would seem the majority of B110s (the SP1003 variety) out there are now old enough to warrant replacement.
3. Should every single driver (bass, mids, tweeters etc) be replaced? I don't think so. The midrange driver covers the majority of what you hear, so replacing the other drivers would result in less of an improvement. The bass driver would likely be the next contender (which I am looking into as I write this), but since it only covers a small portion of the frequency range, will not realize as great a benefit. In the case of my IMFs, the B139 is the next driver to look at, and the FB139 is much more expensive than the FB110 so there is that to consider. Tweeters I still have yet to explore, but I imagine there are similar issues there - perhaps to a lesser extent since a tweeter's movement is much finer.
4. Should this change how you buy vintage speakers? I think vintage speakers are still wonderful. But, it has made me rethink about what speakers I buy, because if the ability to restore the drivers is available, that is more attractive because those speakers will sound better with refreshed drivers. It means a 100% restoration is possible, whereas if you cannot refresh the drivers (either by replacing with new ones of the exact same type or are very very similar, or reconing), you may only realize 80% of their former sonic performance (just an example, not a hard number). For me this is important because I am into vintage speakers partially as a historian - I want to experience what they were like so many years ago.
I think a lot of us go through this hobby thinking that drivers do not get worse with age, and this experience has shown me that it's quite possible that is not true. At least, in this specific example it is not true. However, because drivers are not so different from one another in certain aspects, this is likely something that translates to many other speakers so I felt it worthwhile to discuss.
All right, that was a severely long post and if you made it this far, I appreciate your time. Do you have any experience with replacing drivers with new ones, or aging drivers? I'd like to hear your thoughts and experiences.
