Jon_Logan
Addicted Member
Wow..I can't believe that this still going so strong...Listen to one..that is the simple solution and should be the end all argument. If you do not like what it does so be it...You will at least have first hand experience to share at that point.....As I said before, I have yet to hear a measurement or spec ever....they do not make ant sound. Measurements and specs are tools only. The final judgment should really come from your ears....To me at least, that is the acid test.
Why would I entertain buying one, if there is no reason to buy one? If there is a reason, what is it?
Is it quieter than running without one? No
Can it improve frequency response? No
Does distortion become reduced? No
Is the output impedance lower than a solid state output? No
Why again am I not as much of an audio lover or understander of audio as you? What problem is getting corrected by this thing? How does it know?
Adding things adds distortion and noise. This thing has no gain and no frequency shaping. Why is sliced bread not better than this?
So, I object to language such as "This will improve your system, just listen". "will improve" is a little strong for the level of evidence here. We're not going to get into a subjective listening test discussion, are we?
