As I am saving for a RCM, I am considering the VPI 16.5 as number one on my list. I do not want to spend more than the cost of one of those though because they are costly enough.
I note that it is made of MDF which in my opinion is a bad choice because moisture and MDF or sworn enemies. (On the other hand I don't plan on turning the VPI into a fish tank, so....)
I'm kind of torn because while I don't like the construction material and the cork mat and the noise (not much you can do about the noise). I also don't like the reported heat issues (a fan mod would be in order), I do like the clear vacuum tube and the powerful vacuum.
I'd like to hear some experienced thoughts and opinions from owners, present or past of the VPI 16.5. How you machine is holding up, issues you may have had as a result of build quality or if you've had none and stuff like that.
Thank you.
Thank you.
