rlisin
Quad 4 life
Braun A 301 and T 301 in grey must be one of the ugliest sets I've ever had, so ugly it's actually cool.
Designed by the legendary Dieter Rams (he who 'inspired' many Apple designs, including iPhone and iPad) for Braun in 1978, these two pieces don't look half bad in black (pics borrowed from hifiengine):
Last week I found these in what I thought was white. Described as not working, with bad pics, so I scored them for cheap(ish). Turned out both were actually - sort of - working. The amp needed one new cap and some bad solder fixed, but it still powered up and worked fine with the bad cap when it arrived. The tuner had the same bad cap issue and the dial string fell off. Presets worked fine. So, all in all, way better than expected. Anyway, the big surprise was they weren't white, but grey!
I had them both fixed. A hint for A301, T301, C301 owners: this series has a yellow 0.068 uF cap on the fuse board. This cap must be replaced (even if the unit works, like mine did). This is what it usually looks like, I don't think I need to explain further:
The tuner is very good, and the amp is nothing short of amazing, I think better than the later Atelier series amps that succeeded it. I will compare it later with Braun Atelier A2 I also have. Cool gimmick: A 301 has dual volume control, one pot (left side, marked 'Level') is linear, with separate control for L and R channels. The other (right side, marked 'Volume') is a variable loudness pot, so you have full control on the loudness circuit. To turn loudness off, you simply set the Volume pot to 0 (max) position and control volume with the Level pots. Similar to Yamaha variable loudness solution I think. Works wonders with my Tannoy Venus speakers, I don't think I've ever heard them sound so good! The amp is 32 WPC into 8 ohms, 45 WPC into 4 ohms.
So, here are my 20 inch (yes, they are wider than standard) grey uglies, working their magic with some Van Morrison:
Borrowed a nudie of the amp, will pop the hood and take better pics when I have more time:
So, who thinks I should put these in my living room for my partner's viewing (and listening) pleasure?
