Natrik
Member
Hello, I have a set of Infinity Qb's with an intermittent problem. The high end cuts out now and then, but the weird thing is, the tweeter doesn't cut out completely. While the music is playing, every once in a while it sounds like someone threw a blanket over the speaker. When it happens, I put my ear up to the individual drivers, and the Emit is still working- it's just muted. I thought the problem was with the crossover caps, so I replaced them and cleaned the midrange L-pads. The problem is still there. I narrowed it to the speakers and not the amp or the input by using a different set of speakers, and the problem never happens unless the Infinity speakers are hooked up. Could the fuses be the culprit? I cleaned the fuse holders with DeOxit and they hold the fuses tight, and rotating or wiggling them when the problem is happening doesn't seem to help. I took the Emit tweeters apart and re-melted the solder connections as well, and that didn't seem to help. Any ideas would be greatly appreciated.
