muziekfreak
Well hello there, after a few reviews here. You come to the conclusion, not many have time nor patience to read anymore. However, it's hobby and this is for me a part of it too sharing.
Take anything said here with in mind, I am just a enthusiast.
First impressions
This is a speaker that requires a good amount of space. It's a overly complicated and flawed in its core design. I am a spoiled magnepan owner, so most certainly not new with dipole speakers. A d their inherent, capability to fill a room. With pure ambiance and incredible channel seperation.
It seems super odd by choice, to make a planar mid high panel. To be flanked by a wall sized bass column . That blocks half the panels, and also its ability to do "its thing "
We will see
Set-up
In short a pain in the ass, a old crossover /servo controller that unfortunately came damaged in the mail with it. It can be repaired, but after concluding. That these speakers are NOT SERVO CONTROLLED AT ALL . I opted for a minidsp, it has superior crossover ability and settings. Especially knowing now that the rs1b is not a servo controlled speaker, the controller is a motional feedback system. I will not go indepth , but it works different and not nearly as interesting as servo. And relatively antiquated, any after market crossover will work with the bass towers.
The panels have passive crossovers so no need to worry about that.
My mood, after glancing over these speakers became less and less enthusiastic. They look fantastic, but there are so many things I can point out as ridiculous from a design stand point. But that's how nudell was, genius but also a overachiever.
Sound
After some crossover tinkering, and settling for around 125hz on the bass towers with proper amplitude settings. Press play, it's the first speaker that entered my space that can rival the tympani I I have. It presented itself with the same open no fatique sound characteristics.
Very laid back , yet powerful and puts out a relatively wide sound field. However it doesn't to do to the extend of my magnepans. It's little bit more timid. A little bit smaller and narrow, but that does make sense. The bass towers do block a good portion of its dipole capability. And the tympani is a true line source speaker with its 6ft fall posture and equally wide. It's not , just a magnepan it's sound field abilities. Are incredible..and not many can rival it.
The rs1b is the first in here, that gets close to what Iove about my maggies. Not so weird, as the emim drivers are magneplanar drivers in the rs. It sounds really pleasant, these speakers demand you attention. They produce low end that's so effortless, the 6x8inch woofers per side barely do any work. And fill a room, on any demand you ask from them . After hours of listening it will invite you for more and more and more.
These speakers have so many similarities to what my reference maggie can do. Minus the disadvantages (lacks low end, and it affect dynamic range) low mass drivers. Are just not that good at it, the rs1 has that covered, needless to say . It is a incredible system to listen too ..there are buts.. important ones !
Beware before buying
Now who doesn't dream of a arnie nudells finest, for a fair amount of money you can find these on occasion. There are a couple of things you need to understand.
They are not servo controlled towers, in defense of infinity , their controller (least mine) doesn't say servo either. Add to that it's a very unreliable crossover and known to break. Get yourself a better crossover it helps tremendously..
They will most definitely benefit from a overhaul. The emims, emits these are the type of speakers. That has lots of wiring, connectors, pots what not. These are nearly 40 years old, you can imagine it takes patience and some work.
Conclusion
I do not consider the rs1b a incredible system. There is room for improvement on almost every aspect of the speakers.
However they do cater to what I am in for it.
Musicality, it's rich, full warm , and effortless how these produce sound .. and they look absolutely stunning in any audio set.
I am slowly refurbishing them , they are worth the effort.
First impressions
We will see
Set-up
Sound
Conclusion
