The claim that measurable parameters of an audio amplifier do not correlate with sound quality contradicts well-established principles in audio engineering. Tools such as Audio Precision analyzers are not just "go/no-go" testers but precision instruments used to optimize and fine-tune audio equipment. These analyzers provide valuable insights into key performance metrics like Total Harmonic Distortion (THD), Intermodulation Distortion (IMD), and frequency response -parameters that are scientifically linked to perceived sound quality. Research consistently supports the idea that lower distortion and a flatter frequency response contribute to more accurate and pleasing audio reproduction, as demonstrated in numerous studies and publications from institutions like the Audio Engineering Society (AES) and Journal of the Audio Engineering Society.Note:
It is completely unclear what kind of analyzer we are talking about. Until now, no correlation has been established between sound quality and any parameter of an audio frequency amplifier. Measuring devices such as Audio Precision are used at the end of the assembly line as a"go/no-go" tester, nothing more.
The propagation delay in op-amps and audio amplifiers, particularly regarding the input-to-load delay and feedback delay, is a well-understood phenomenon in audio engineering. These delays can lead to measurable distortions and reduced signal fidelity if not properly managed, which is why amplifier designs carefully control these parameters to minimize any negative impact on audio quality.https://en.wikipedia.org/wiki/Propagation_delay
Propagation delay
Propagation delay is the time duration taken for a signal to reach its destination. It can relate to networking, electronics or physics.
Note.
In a number of modern high-speed op amps, this parameter is specified as time Propagation Delay and is measured at a gain of 1 or (-1) between the input and output when the signal crosses zero.
As for audio amplifiers, two types of delays can be distinguished here:
-propagation delay from the amplifier input to the load (this parameter determines the vector errors of the amplifier and distortions associated with the rotation of the fronts (slopes) of signals during the attack, decay, and more);
-propagation delay between the input RF filter (if used) and the output inductance (if used). This time determines the NFB response speed and the switching distortion suppression in class AB amplifiers that depends on it.
Dynamic measurements such as impulse response, FFT analysis, and group delay testing are essential for identifying issues like switching distortion and group delay, which affect the transient response and overall sound quality of audio amplifiers.
it's very much an issue that is taken care of by design.
To mitigate these problems, manufacturers employ advanced circuit design, fast op-amps, optimized feedback loops, and high-quality power supplies.
