Interesting tube and related audio site.
doucanoe
Registered Audio Abuser
I found it searching for information regarding SE tube amp designs.
http://www.nutshellhifi.com/library/index.html
Also, if you look down to the last entry on the first page, there is a link to the .pdf upload of the book, Getting The Most Out Of Vacuum Tubes.
Here is what they had to say about it.
"Written in 1960 by Robert B. Tomer, a CBS Electronics engineer, and an essential resource for all engineers and designers working with vacuum tubes today. I'd like to thank John Atwood of One Electron for the scan of this rare and long out-of-print book"
I thought it might be interesting for those who have not come across it before.
RC
nice :thmbsp:
downloading and saving for later :nerd:
I've been on the Nutshell Hi-Fi page before . . found it linked off of tghe Sakuma Sound website (or vice versa - its been a while...)
Also the "tiny history of hi-fi" article is pretty great reading...the one thing in there that caught my attention particularly is the story about the dynaco ST-70 wired in triode beating all the expensive SS amps...does anyone here have experience with wiring that amp in triode? I have a pair of MK IV's and I'm wondering if they would be improved by triode wiring, and if so how to do it...just cutting the screen and suppressor connections or something?
Triode connection of the outputs simply requires disconnecting the UL tap wires from the screen grids, green and green/white wires, and safely taping or heat shrinking them off. Then the screen grid, pin 4, is connected to the plate, pin 3, via a 100 to 150 ohm 1/2 watt resistor, on each output tube. More detailed info is at Curcio's website: http://www.curcioaudio.com/ST70 OP Triode Conversion.pdf
Hope this helps.
Mike
For the record - I just did the triode conversion on my Mark IV amps and WOW, they sound great! I feel like I'm getting considerably more bass. They sound really nice though. Maybe less detail, but more balls. Which is interesting, since it's like 1/2 the output power.
Very cool site,
The "triode" connecting will work better on some amps and tubes then others.
My 6AV5 amp is running "triode" connected and works very well, haven't had the
same experience with most tubes on an ST-70 but Squid has with his quite often.
Well, I was never particularly happy with how these amps sounded - I put Curcio boards in them before ever hearing them stock, but felt like they sounded a bit flat compared to some other things I've heard. They definitely don't sound flat anymore - seems to me much richer and more dynamic. A bit darker, so I inched up the upper-mid attenuation on my Altecs. They sound great to me now.
I'm glad it worked out for ya, currituckco. Not only for you, but I woulda missed this thread if you didn't post again. ;)
