Vintage_Hi-F
Vintage Audio Geek
Is it possible that your Marantz has the codecs to decode MP3/AAC/Apple Lossless etc...?
Most likely, yes. All those Codecs are open source so you don't have any royalties to pay to any individual or company.
The music files are hidden. They are there in a hidden folder. I went and tweaked the Mac OSX settings to read hidden files. There are lots on the iPod that can only be accessed directly by the iPod / iTunes normally.
or if you're in windows just go to folder options and tell it to display hidden folders and bingo inta-files (it's all starting to come back).
Yes, it does.
The only hitch I see is that in certain condtions AAC could have copyright protection (purchased downloads from Apple?) and the manual says these will not play this way (by USB).
Yes, it does.
True and those file would probably need the "authorized" dock to be playback. Though if all you're music is ripped from you're own CD collection than you've got no problems.
Yeah, the protected AAC files (.m4p) have DRM and they come from the cheaper downloads from iTunes. PITA IMHO:thumbsdn:
That's why I stick with just ripping my own CD's and stay away from apple or Zune for that matter.
Ahh, there is nothing wrong with Apple or iTunes. It's just a computer and a program.
Personally, I use MAX 0.91 for ripping instead of iTunes. MAX can let the bitrate loose and go as high as 390 kb/sec for AAC files, and they are still iPod compatible. Sound (to my ears) 99.8% as good as the CD when done with MAX.
iTunes does a good quick job, but the error correction is rudimentary at best. MAX can do SHA-256 sector comparison, check for C2 errors, plus it can do multiple passes of sector and only rip the matching sector passes. In short, after all that error correction, I'm getting the cleanest rips possible.
iTunes is a great player, and I use it alot. Ripping.....well, it's basic.
I have music available wirelessly around the house, too.Convenience I guess?? It doesn't make sense to me either as I had the same questions at the Wadia presentation.
If your computer isn't near your main rig, access is an issue so the Wadia allows you to plop your iPod, (or a friend's) into a cradle and away you go. But I play my stuff via a netbook that accesses my main library wirelessly, and then output it to a DAC and into the big rig, so I see no need for the Wadia or any similar device.
I'm tapping into the mother lode, not some portable back pack![]()
5. While a netbook can do some of the above, it is not as portable and it would still need some sort of DAC to get better sound
You misread my post; all the netbook does is run my music software. It's output feed my V-DAC. I'm more than the 5m away from my rig and don't want my computer sound colliding with my music, so I run the music off a separate computer wirelessly.
Sure I have to go to it to change selections, but I have to do that with any other media so that's a non issue. Using shuffle, I can play weeks of music with the only repeats being duplicate copies. My iPod Touch is only 16GB; my desktop HD is 1TB with 160GB of music on it. Guess who wins???![]()
