Is it a Bird? Is it a Plane? or is it a Pioneer PL-7 Turntable?
Tom Elliott
I recently bought a very early (1960) Pioneer PL-7 turntable. I managed to track down a complete set of original paperwork and I'm very happy with it all. Frankly I think it's a Japanese knock off of a Garrard 301. It's very simple, built like a tank and employs idler wheel technology.
However Pioneer seem to have made another PL-7 that's nothing like mine. A simple Google search will take you to a semi modern unit with all the bells and whistles.
My PL-7 was also named the PL-7UB, the only difference being that the UB version came mounted in a, quote "simple" plinth. In full disclosure, the picture I posted of an original PL-7 is not my actual turntable.
Have any of you run across this odd situation? Do you have any opinion of the "Original" PL-7 turntable?
I have an original PL-7 like that in the picture, with paperwork, though my base isn't as nice as yours, conditionally!
In no way is it a knockoff of a Garrard 301, other than it's a 3 speed idler drive turntable! There's no pitch control, the tonearm is supplied, fixed, and integrated, it has built in cuing, and is of much, much lower quality than a 301.
The PL-7ub is a VERY stylish and retro looking turntable-someday I'll even have to listen to it!
Hi Dave, Obviously you are correct in your comments. What I really meant was the Pioneer is way over built and should last a lifetime, just like the 301. Also it's simplicity reminds me of the 301. I also have a 301 and frankly there are a few things I prefer about the Pioneer !!
I'm a charity shop hound by the way and I found my Garrard 301 a couple of years ago, sitting in it's box complete with all it's original paperwork. It also had the accompanying Garrard TPA-12 tone arm and a Garrard tracking weight scale. I thought I'd take a chance on at at $50.00 :)... It's still sitting in it's box but my eventual plan is to mount it (dual arm) with an SME tonearm and use the original Garrard arm for playing 78"s.
You are right about Pioneer recycling the model name. The later PL 7 and the other tables in the range were pretry good sounding, and as I recall, they came with both standard headshells and Pmount headshells. But every one I've encountered has had a tendency to suddenly jump to incredibly high speed rotation. I cleaned the pots etc, and they behaved for a short while, then started going bonkers again.
Yours has the very great merit of doing what it does with no likelihood of misbehaving.
Hi Nat,
Simplicity is the key to early PL-7's.
Basically there's very little in it to go wrong. It's just a motor that manually turns off and on, and a tone arm that is also manually operated.
But even being as simple as it is there's still a multi capacitor that dries up over the years causing the speed to become unstable.
So maybe the continued link between the original PL-7 and the later version is that they are both able to fail !!
Thank you for your input,
Tom... :)
