It's a Fen-Tone!
Lucky Pierre
AK Subscriber
Picked up this Fen-Tone Mark 8 amp yesterday. It about 1.5 watts, SE 35C5 with a hot chassis. I can't find any information anywhere on Fen-Tone, but it is remarkably similar to Monacor SA-10. Probably one of the late 60's Japanese manufactured amp that was sold under different names. And, yes, the bottom is cardboard.
Super long shot but any idea where I might find a schematic?
It seems that the amp has no power transformer but the mains is rectified.
Check the Mullard Seven-watt DC/AC amplifier schematic.
Your time would likely produce more results by drawing out a schematic of it yourself, as l’ll bet you’ll find the needle (in the haystack) before you’ll find a schematic…….
Good luck with it!
Dave
Good luck with it!
Dave
I have never done this, but I can give it a shot. I found the site SmartDraw. Any experience with it?
Okay Pierre, have a look at the Mullard seven watts amplifier; it’s the same principle: https://www.gammaelectronics.xyz/mullard_amps_1963_8.html
You don’t need a software to draw the schematic; the data sheets posted above will help you identify what’s connected on each pin; the heaters are connected in series.
A word of caution, there is no power transformer, the rectifier is directly connected to the mains.
There are 89 models listed on radiomuseum.org using those tubes, 81 of them providing schematics. There are two basic schematics, one for stereo, or push-pull for mono, with differences in the tone controls, use of feedback (see Motorola HS-703), some differences in component values. Stereo is simpler, same circuit twice. And one by Radio Shack has two 12AX7s - ignore that one! I could draw a schematic but would be guessing some values of resistors and capacitors.
From my recollection, Fen-Tone was one of those Japanese brands that small independant electronic stores sold in the early to mid 60's. First guitar pickup to make my cheap acoustic guitar electric was a Fen-Tone. I know they had a line of microphones, and pretty sure bits like cables and plugs.
Still have that old p/u, in its original box ;)
I had a small 6V6 PP.mono amps sold under the "Hi-Fi" brand. It was Also sold by Radio Shack, and had a few other brand names slapped on the same amp. It was acually a decent sounding little amp.
It was also a Japanese made amp.
