JBL M5 (chinese) low-freq rattle/buzz, foam removed; refoam/fix or buy replacements?
sharky_pi
One of my JBL M5's is rattling for low-frequency tones. I took it apart, removed all the expired foam, and put it back together, to no improvement.
I'm only now reading about re-foaming. Given the speaker otherwise looks fine, do folks think that re-foaming should probably solve my issue? I.e. the rattling would definitely be caused by a lack of foam?
I'm seeing other threads [e.g. 1,2] discussing the variety of other potential problems, so I don't want to dive in, pay the money, go through the fix process, then have the same issue.
Also I presume this is the right kit (it says it's for JBL M5) but just wanted to check with someone. Thanks all!
The speaker will never work or sound correctly until it is reassembled correctly.
So..yes it needs to be refoamed.
That appears to be the correct foam; many AK'ers have satisfactorily used SS for foam for many different speakers. However, I'd suggest watching a few Youtube videos on refoaming to be sure it's something that you're comfortable doing. It's not simply a case of gluing the foam on and calling it done; it needs to be precisely aligned to work properly (although the amount of precision required varies from speaker to speaker).
Nice one, thanks folks. SS videos look super helpful, pulling the trigger now. Have a great weekend both, cheers!
I note that your speakers have the original foam mounted to the underside of the cone. This does make the job a little more difficult, as the replacement should be attached the same way.
