I've been reading lately about some technicians testing capacitors and putting them back in aging equipment (30+ years old) because they test "in spec" -- no test results listed.
My brother brought me a digital readout to look at the other day, stopped powering up a while back. No power on lamp, no activity.
I did a bit of digging, and what I found was that it has a power down function for the computer if the + and - 15V rails are not right, plus of course won't operate at all if the +5 rail is below 4.2V or so just like all digital computers of that age -- made in 1997. Suggested repair was replace the PS caps.
So I bought the recommended set (Nichicon UPW) and replaced them. All tested "in spec" although the 68uF 400V switching PS main filter cap read 51 uF, None of them were over 1.2 ohm ESR, leakages were all 2% or less.
However, after replacement it fired up perfectly. I'm thinking that means ALL of the caps less than 100uF I pulled from my second KA-80 last week are bad and were probably affecting the sound somewhat.
Moral of the story: Even if old caps test "within 20% of rated capacity" and have reasonable ESR, they can still be causing trouble!
