Hi, newbie here and hoping someone might help me out. I came into a pair of KEF 101/2 speakers. There's virtually no information on these online except they were made in about 1990, they use a single Uni-Q driver, and they were pretty expensive new.
They look pretty good with nice wood veneer, a little TLC and they ought to look extremely nice. The drivers look literally like new, no visible problems. Unfortunately, there are some audible problems.
I set them up with my receiver and fed them a white noise (or pink noise) test signal. They both played, but one at a much lower level than the other. Since it has bi-amp terminals, I tested the woofer and tweeter separately. I took off the jumpers and hooked the wires up the the LF terminals. One speaker has a very low woofer output. I switched wires to make sure it wasn't the connection or the receiver. It's definitely the speaker. Then I hooked up to the HF terminals. Much better, approximately equal in volume.
Then I did a listening test with some music. It seems that the speaker with the good woofer has an issue with the tweeter. :tears: There's a definite loss of higher frequencies.
I haven't opened them up yet, which seems to be the next step. I've read about the crossover caps going bad, and these are nearly 20 year old speakers. Can bad caps cause my symptoms? I would expect a bad woofer or tweeter to be totally dead, instead of partially functional. Thanks in advance.
Royce
Royce
