Kenwood Eleven GX
drbacklash
Does anyone have the bias and offset specs and adjustment procedures for this unit? The left DC offset is running about 45 mV and I can find pots (but no test points) for the bias adjustments.
A copy of the SM woule be even better. They are hard to find.
I have turned the internet upside down trying to find a service manual for the eleven gx. In desperation, I bought one for the eleven hoping it would provide some useful information. Everything is different between the two models so I'm still at square one.
The unit comes out of protection and the left channel is fine. I can even adjust the bias to what I think it should be. I get no bias reading from the right channel but I get a distorted sound from there. I've cleaned pots and switches and replaced all the caps except the tuner board. I thought I had found a bad diode but it tested good after I pulled it from the board. I did notice that the output transistors (which tested good) did not have the silicon insulators on them. I will correct that soon. I also noticed that some power supply transistors have been replaced in an earlier repair but, without the SM, I don't know if they are the correct ones.
Surely there has to be a service manual somewhere for the Kenwood Eleven GX. Any help here would surely be appreciated.
Thanks
