Kenwood KA -9100 Intergrated Amp Restoration
Thanks. It helps if you are looking for local or reasonable traveling for tech people.
These units are getting expensive to ship the proper way. Unless cost is not a problem.
Also if you want to attempt to do it yourself, you can start a thread about it and go from there.
Cheers :beerchug:
John
KA 9100, I opened the amp and cleaned it out with Compressed gas duster and cleaned out with QD contact cleaner. May need to do QD contact cleaner again. Hooked up speakers and the tuner, I have a good signal on tuner, but only getting sound and the wattage meter shows wattage - power output from the left side only. These units were in storage for 30+ years. Any suggestions or advise???
Start your own thread.
Not sure what you mean, regarding checking the power supply, please explain. Is there anywhere in So calif, where I can have this serviced?
What he meant was to start your own thread as to not make this one about multiple problems.
Go to the top of this page, click on the Kenwood-Trio/Kensonic-Accuphase link that's in darker blue. Then at the top of that page to the right you'll see an orange Post Thread button. Click on it and start your own thread with the problem and any questions you may have.
Welcome to the site.
