Kenwood KA-9100 The LEGEND!
Pictured is c4 on the amp board. The scat says 100uf/35v. The cap installed (on both sides) is 1000uf /35v…….why would a tech do this?
I will revert to the original value, using a 100uf/50v Panasonic cap.
FYI:
If you're not rebuilding the amp boards, at least put a multi-turn
pot in place of that single turn. 470-500 ohms works fine.
The offset will be easier to adjust
and the offset will be more stable.
