ecluser
I did a light cleaning of the pots and switches when I started, but after reporting the DC offset, and reading some other posts in AK on bad channels, I did it again. Including the Normal/Separate switch at the rear. I left it to dry out overnight.
I just want to be sure that you proceed corectly with the contact cleaner.
You should spray the contact cleaner inside the control (or switch), and move the control from one end to the other several times just after spraying, when the control is still wet of contact cleaner. Repeat a second time.
Some switches are not easy to clean. I often drill a small hole at the rear of the sealed switches to make sure the contact cleaner reaches the contact inside the switches. Again, you must move the switch at all positions several times when the switch is wet of contact cleaner.
Before replacing the relay, compare the sound at pins 20 (L out) and 16 (R out) on the power board.
