Me Tarzan
EARTH
Seriously considering picking up a pair of KRK Rokit 10-3 G3's without auditioning based on reviews alone. They will be replacing a Frankensystem that sounds pretty damn good to me but too big for the room (12x14) and not good for mixing. All sources will be digital (computer usb, mixer usb, optical) fed into Emotiva XDA-1 DAC balanced out to KRK's. Currently the XDA balanced runs to Soundcraftsman 2502 feeding Infinity RS6000's stacked upside down on top of a pair of Toby speakers powered by a Cambridge integrated from the XDA unbalanced out. Definitely a wall of sound for the small room, and I would like to keep it loud but clean up the sound and free up some floor space. These speakers would end up being used as daily listening speakers at least 75% of the time with 25% going to mixing/recording duty. Just about every review for these speakers agree that you can do no better for the price, about $885 delivered is best I can find. Extremely loud, extremely clean and accurate, so they say, but can't find a place to audition. Anyone had a chance to use the KRK 10-3's for a while or even have a listen? Would be nice to hear the 35hz in person but close to just chancing it.
Tweeter: 1" Neodymium Soft Dome Tweeter
Mid Frequency Driver: 4" Glass Aramid Composite Midrange
Low Frequency Driver: 10" Glass Aramid Composite Woofer
Frequency Response: 35 Hz - 25 kHz +/- 2dB
SPL: 113dB max
Dimensions (H x W x D): 21.2" x 12.7" x 14.3" / 54 cm x 32.5 cm x 36.5 cm
Weight: 46 lb. / 20.8 kg
Amplifier
Power rating: 140W RMS
Signal to noise: 98dB
T.H.D: .08%
Input impedance: 10kohm
Balanced: 10kohm
Unbalanced: TBD
Crossover
LF-MF: 400 Hz
MF-HF: 3.75 kHz
Input:
XLR (3-pin)
RCA & 1/4" TRS
Power In: IEC mains connector
System volume control: -30db to +6db
Power indicator: illuminated front logo
LF adjust: - 2dB / -1dB / 0 / +2dB
HF adjust: -2dB / -1dB / 0 / +1dB
SPL: 113dB max
Amplifier
T.H.D: .08%
Balanced: 10kohm
Unbalanced: TBD
Crossover
LF-MF: 400 Hz
MF-HF: 3.75 kHz
Input:
XLR (3-pin)
RCA & 1/4" TRS
