Speaker builders use manufactured wood products (mainly MDF, particle board or plywood) because they don't warp, and the density is more or less uniform across the entire sheet. The same can't be said of solid wood. With good quality veneer work, in theory a speaker cabinet could be made that looks exactly like solid wood, but isn't (I'm not saying that's the case here, just pointing it out).
