Rex Aeterna
Gigolo of Gigolos
i plan on replacing the power filter caps pretty soon on this amp. just want to know what is the possible largest cap i can effectively go to with no modification to the amp at all? i just plan on replacing them since the amp is over 30yrs old by now(made in 1985) and just would like to do it to increase life-span and peace of mind for another possible 25-30years. i wouldn't usually do this but, it is a defiant keeper in my stable so would like to treat it a bit.
seems like nichicon is only one that makes the larger caps but, are more pricey than i thought so i know just replacing these two guys is gonna be expensive. the original caps are 100v 10,000uf and was thinking of getting a pair of 160v 33,000uf caps from digi-key. i believe increasing the voltage and capacitance is ok from what i read... i just don't want to go too large since while there is good bit of space inside i'm just concerned on the diameter size limit. i think 90mm is thickest it can go inside...
i just want to get an idea on limitations i have and advice will be much appreciated it. i have forgotten a lot of stuff over the years so, while i remember some things, i forgotten lot of other things. i am even going to have a local tech i known for years to replace the caps for me out of comfort of knowing someone with over 30 years of experience is gonna handle it for me.
everything else was replaced in the amp it seemed when i looked inside. guess it was recently serviced before i bought it from a local guy i met cause, all transistors and everything else is brand new and marked. just the power filter caps was left a lone so, i am thinking of replacing them in the near future myself. anyhoo, enough babbling and any advice is welcome and of course very much appreciated. thank you.
