A lot of good advice here, but based on some of the comments, I'm not so sure I need room treatments. My listening room has heavy padding and carpet and wood fixtures. If anything it isn't as "bright" as I would like. Bass is not at all boomy or muddy, but solid and both stand mounts and sub are well coupled to the hardwood floor underneath.
Your comments show you probably have all your bases covered.
You know, room treatment is a medicine, but any medicine is useless - even dangerous - if you aren't sick
But, since we are discussing, I've spent about 2 years visiting dedicated forums, trying measurement software, reading books and experimenting as I had a new toy - a dedicated listening room.
When it was just completed (concrete and brick walls, plastered with plastered concrete ceiling and wooden planks on a concrete floor, it sounded terrible when it was empty.
Flutter echo and bass boom was all it exhibited.
But as it was filled with stuff I was going to put in there anyway, things started to change. It still has a large peak at 31Hz (lowest room mode) but music content rarely has significant content down there to actually trigger that mode. And placing the couch with a bit of care, I was able to avoid the resonance across the length of the room.
There are some schools of thought that promote the use of absorbtion throughout small rooms. Obviously taking care to leave some reflection so as not to destroy mid/highs.
But there's another school of thought that tells you to leave the room as reflective as possible, so that sound can create envelopment.
And even if the room has some issues, the brain learns to compensate for that so after a little while the sound seems fine to the "trained" listener.
I did employ some room treatment mounting considerable sized corner traps to the two front corners, adjacent where the main speakers are located. I did this as they (KEF 105.1) did sound boomy, even at moderate levels. After mounting the (DYI) corner traps sound was tamed to the point I can raise the level to the point I enjoy a rather flat frequency response while low frequency energy seems to trigger the leather couch at times.
I could go a couple of steps further and build a couple of diffusers mounted on the ceiling between the listening position and the front loudspeakers but I don't really see the need to focus on treatment and not enjoy what I currently have.
