No they are supposed to connect. They are the two 180R resistors in the B+ line.They saw their joints look suspicious I don't think they should be bled together with the soldiers touching the second photo is of the item that is soldered down I don't think those leads coming out of there should actually be touching each other.
Good you found it. Be interesting to remove the PT and dissect it, to find the short. It could be one of the leads.. EDIT, i cut the HV wire and it still blows fuses it's the Transformer for sure and this project is officially dead, thanks for all your help, until the next project. I did learn a lot from this. I wont be buying a transformer for this, i will gut it for parts.
I guess another Little Dot Mark II is off the wish list.. EDIT, i cut the HV wire and it still blows fuses it's the Transformer for sure and this project is officially dead, thanks for all your help, until the next project. I did learn a lot from this. I wont be buying a transformer for this, i will gut it for parts.
Interesting. You take that PT apart? Maybe, it's an easy fix?It was free so no big deal.
Are there any Little Dot MkII "for parts," on eBay?You know it really would all depend on how much the Transformer would cost me I'm not going to put $100 into a transformer into $150 amplifier.
I'm thinking one wire maybe pinched up against the transformer's chassis --- when the factory tighten it down.Carefully check the wires going into the transformer first before tossing it.
Maybe there are a couple wires touching? A tab where the wires connect got bent and is touching another?. Some of these transformers with tabs have the wires soldered to them. Or the thin wires coming from the windings to the tabs are touching maybe. If it's an R-core transformer, they tend to be pretty cheap. Maybe around $20.
I'm hoping you can fix it. If it's the internal windings (shorted to ground) --- use the transformer as a paperweight.Okay I'll check the I'll check the Transformer I'll check all the wires in the winding I'll take a picture of it that way you can give me some kind of idea what it may cost like I said in the beginning if it's not very expensive I'd be willing to replace it.
Yes, that is the proper method to test the PT.But further back in this thread the guy said if I cut one of the high voltage wires and turned it on and it still blows the fuse the Transformers dead that's what he said I don't know if that's true or not because I don't know enough about this I'm just going off of what he said.
