OK. I'm getting ready to experiment here.
I have a pair of Bogen amp chassis... voltage doubler supply, with about 600v plate voltage. Each has an OPT, with about a 4.2K primary. They also have available tertiary windings, which would give about a 25%, ultralinear, connection for the screens... which can be connected to a lower B+ voltage (300v, easily had from the center of the voltage doubler power supply).
From looking around at the UL and pentode curves... it looks like this might be a good alignment. The UL ratio is less than "normal" (25% vs. 43%- closer to pentode mode than normal), but the primary impedance is higher than normal UL (4.2K here, as opposed to about 3.3K recommended for the 6550, in most tube manuals for UL).
It looks like this might be a good load-line for this tube... 4.2K, 600V plate, 300V feeding 25% UL from tertiary tap to screens...
Anyone see any big problems with my off-the-cuff derivations here? My only concern is possibly the lower screen voltage affecting the output impedance of the tube... but, it looks like it should be much less change than straight pentode mode would be, compared to "normal" UL mode (plate and screen at the same voltage)?
BTW: I'm probably going to use a set of Valve Arts 6550s in this amp, at least as a start. I got 'em, and they're supposed to be pretty darn good...
As for circuits for these- I'm still waffling between the Citation II and Heathkit W6 type architectures (Hegeman vs. Williamson, in essence)... though, with the reduced screen voltage (higher gain?) on the output tubes, a Mullard circuit might work?
Regards,
Gordon.
Regards,
Gordon.
