whoaru99
Epic Member
Later this summer I'm going to provide the stereo system for a gathering out at my Uncle's place. I'll be using my "garage stereo" that is comprised of sound reinforcement speakers & subs, a stack of pro amps, and a speaker management box for crossovers, tunings, delay, etc.
I will place the amp rack behind the speakers, and all that will be set up not far from the power hookup, away from the main "audience" area. However, I want to run the volume and global bass/mid/treble adjustments from a small mixing console reasonably far from the stacks and racks, so to speak.
I'm thinking I will buy a 100ft length of shielded, stranded Cat5 cable and put some XLR connectors at each end. To, in effect, make a long interconnect for the left and right channel connection between the mixer and the speaker controller.
I'd wire it up in a "star quad" configuration, using (for example)-
White/green & white/blue for Left (+)
Green & blue for Left (-)
White/orange & white/brown for Right (+)
Orange & brown for Right (-)
Certainly this would be a somewhat fragile cable not suited for touring duty, but for temporary backyard party so to speak I think it will work pretty well. Cat5 cable, having low capacitance, mixer with 150 ohms output impedance and speaker controller having 20k input impedance, balanced connection, 100ft (assuming I even use all that) should be no problem, eh?
Thoughts?
Thoughts?
