Lubricate Cassette "Slider" Mechanism?
Marty C
Is it necessary to lubricate the head base slider mechanism on a cassette deck?
I have my TASCAM 246 cassette desk opened up to replace the belts and idler assembly, and I wonder if I need to do anything with the mechanism on which the head slides in/out of the cassette tape path. I've cleaned the head religiously, but I haven't touched the plates on which the head moves. There appears to be some sort of light lubricant on this mechanism, judging by the dust and Q-tip fuzz sticking to it. But, after 25+ years, whatever lubricant is there probably needs renewing. Or, are these mechanisms generally *not* lubricated and it just needs a good clearning?
Other posts on cassette deck care seem to imply that a cleaning with alcohol would suffice, but I'm not sure if that's the right thing to do for this mechanism.
Thanks for your help!
Marty
It probably had some white lithium grease applied at the factory. I would re-grease any areas that have residue of old grease, after cleaning off the old. A little dab'll do ya.
