Mchaz
Outputs roasting on an...
Well, I was enjoying some King Crimson (see avatar) at less than responsible levels, and my left channel took a dump. As I was rushing over to power down the system I took note that the lights on the corresponding mono block were dead. Just a fuse, I thought!
Well, the replacement fuse blew within the first few seconds after power-on. Upon checking the outputs I found one of three 2SD665's (NPN) with E-C & E-B shorts. Also, one of three 2SB645's (PNP) has an E-C short and E-B open. Is it common to blow just one pair of transistors in an amp with paralleled outputs like this? Are there common causes for outputs to blow like they did? I attached schematics in case anyone wants to take a peek.
I still need to poke around the driver section and check devices, but, thankfully, nothing looks toasty. Some searching revealed that MJ21195G and MJ21196G are good On-Semi replacements for the outputs, and the prices aren't bad at Mouser.
As promised, nudies!
