I have no Idea I've been offered the stingray at a great price that I could compair the two and keep what I like.Completely different animals. What exactly are you looking for in an amp?
A lot of my system is Manley, the reputation is well earned.I've always wanted to hear some Manley products. They have a great reputation. Owner, EveAnna, is someone I'd like to sit down and have a few beers with. She's a Rock'n' Roll fan so I would expect her amps to have plenty of boogie factor.
-Dave
the 45 in not mono but they did have a headphone one, see videoThe Manley’s an integrated amp, but should sound pretty good... Manley does a really good job with their transformers, which is the most important thing in a tube amp.
The 45’s are moboblocks, aren’t they?
So far the 45 is killing it!I've always wanted to hear some Manley products. They have a great reputation. Owner, EveAnna, is someone I'd like to sit down and have a few beers with. She's a Rock'n' Roll fan so I would expect her amps to have plenty of boogie factor.
-Dave
now this is the kind of stuff I wanted to learn.So -- the Stingray is a cool amplifier that uses a quad of intrinsically good-sounding little power tubes (EL84s) in push-pull parallel to get "high" power (ca. 30 watts, maybe more depending on the operating points). It wasn't a new trick (e.g., the EICO HF-32 mono integrated amplifier was PPP EL84; Sherwood made a PPP EL84 or 7189 mono integrated, too) -- but it does put a lot of stuff (relatively speaking) between the signal and the loudspeakers. The SE 45 amp -- simply put -- doesn't.
The Stingray, of course, is indubitably more powerful, but it may (?!?!?!) lack the immediacy of the SE direct-heated triode amplifier.
Will you hear a difference? Probably. Which will you prefer? That's gonna depend strictly on your ears, your listening space, and your taste in music.
FWIW, I prefer SE DHT amplification and that's what I use here with Altecs (SE 2A3) -- but my ears and brain ain't yours.
Oh, one other thing, SE 45 ought to sound superb on Valencias -- but they're certainly on the low end power-wise; that could be a factor (depending, again, on your space, the kind of music you like, and your typical listening levels).
HTH, as they say.
If I were to get one, it'd get the Manley for flexibilities sake. I believe that power matters, and you can't meet all musical needs with a couple watts.I'd get both if you can swing it, neither can do what the other can, it'll be nice to have both available..
Ok it helps the vid for sound quality if you mic is at the seating position. A kind critique, I'm not feeling air and space in your vid and nothing in the low frequencies.You have lots of nice gear but I think you maybe need to slow down the buying and work more at setting it up and the room better. The wall your on probably only will fit one pair of speakers to space them wider apart and get better imaging.heres the moth and altecs singing this amp with the mods is great! I dont think the manley going to sound like this. i have no idea why he stop making it!
