I went back in to a 1060 I worked on 15 years ago or so. I had used some ixcon e-caps, so I replaced them all with good e-caps. All the e-caps are done including the large chassis mounted caps. All is working. I like to change the trimmers on my gear too but how far after that should I go on this 1060? I was thinking output transistors and drivers etc. too. I couldn't find much info the transistors in question track life, and will all replacements get along with each other in this 1060? I would like to stay with metal type transistors.
2sc595 = 2n3440 or 2n3439 heat sinked
2sa606 =2n5416 or NTE 397
2sc897- mj21194 or mj21196 outputs
Any suggestions? thanks
