I received a Marantz 2275 yesterday from a seller on USA Audio Mart. It is pretty banged up, slight bend in the lower rear chassis and the balance slider is snapped off which did not show up in the pictures. The right channel is out but both power amps work so I will troubleshoot the pre/tone board after I re-build the power supply board. It looks like the power supply board has been worked on before, new relay and some of the caps and transistors but since I have the parts I will re-build it anyway to play it safe. The right power amp board has new output transistors installed and new driver transistors also.
My biggest issue is that the Lamp Housing is completely toasted, the tabs that held it in place are gone and it is quite melted. There were some available on the auction site but currently sold out. I messaged the seller to let me know when more were available.
In the meantime I will start working on restoring the amp. The tone slider will be interesting but I an hoping I can fashion something to allow me to attach the slider knob to the shaft as electronically the tone slider is fine.
