-Why the power supply?
You started with the power supply. Given your description of the issue, where both channels are breaking up after a few minutes of use, the power supply is a reasonable suspect. This is because it is the source of power for all of the circuit boards except for the main amplifiers. So an issue with it affects both channels. There are not many parts in common between the main amplifiers. They are powered by leads from the transformer, going through a rectifier, and then to each amp. So the transformer and the rectifier are the only parts in common between the main amplifiers.
-How to be sure
The main amplifiers, rectifier, transformer, the protection circuit, the relay, and the main/remote speaker switches can be tested and ruled out, just to be sure. There are two ways to use the Main In/Pre Out jacks to do this:
1. With the 2325 powered off, connect a music player to the Main In jacks. The music player can be a phone. It has to be something with a volume control, because the signal will be going straight to the main amplifiers, bypassing the volume control on the 2325. With the volume on the music player turned all the way down, turn on the 2325. After the relay clicks closed, slowly turn up the volume on the music player to a normal listening level. Then wait to see if the issue occurs.
2. Or you can use the Pre Out jacks to confirm the issue is before the main amplifiers. Connect the Pre Out jacks to the inputs on another receiver or amplifier. This way the other receiver is the main amplifier, and the 2325 is just a pre amp. Connect your source to the 2325, and speakers to the other receiver. Start with the volume control on the other receiver at about 12 o'clock, and slowly turn up the volume control on the 2325. Wait to see if the issue occurs.
The second test is more definitive, but either will serve.
-Back at the power supply
The power supply provides 35V, 19V, and 14V. This redrawn schematic for the power supply board shows everywhere the power is distributed (highlighted):
1. J805 (35V) supplies:
PH01 buffer amplifier
P400 phono amplifier
P300 MPX amplifier
PU01 FM muting
PE01 pre/tone amplifier
PT01 tape monitor
2. J806 (19V) supplies:
P600 Dolby amplifier
PL01 Dolby meter
3. J807 (14V) supplies:
The Mode switch, for power to the stereo lamp
The Selector switch, for power to selected AM and FM boards
Whew. That just saved hours studying the schematic. It also helps with where to focus on the power supply. Issues with 14V or 19V outputs are unlikely to affect the sound as described. That leaves the 35V output which obviously touches a lot.
-Where to go next (after doing the Main In/Pre Out jack tests)
1. Looking at the simplified schematic, the voltages are marked in red at the transistors H802, H803, and H804. Checking the voltages at those locations before and after the channels distort may prove useful.
2. Freeze spray on the three transistors, one at a time, or the rectifiers at H808/H809, may reveal a heat related issue with them. The suggestion that there is a connection failing on the board is also valid, and might be located with the use of freeze spray on the foil side of the board.
3. Were there any semiconductors in the parts you replaced on the power supply? Or just capacitors?
Many thanks to Tim Cartier for the redrawn schematic, and for documenting what every single lead connects to on a 2325. Including paths through the switches.
-Randy
