Hi everyone,
I’ve just taken delivery of a Marantz 250M I ordered online from Japan- SN 30308. I’ve seen a number of posts on this site about 250M repairs so I thought I’d run you through what I’m doing in the hope of getting your tell your advice and suggestions. So here goes!
The unit appears in decent shape- with the major exception that someone cut two big holes on the back to fit a pair of XLR sockets for the speaker connections. ☹
I’m not to impressed by that… so my plan is to fix a backing plate on the inside then I’ll fill the holes with body filler, then paint over the top. It won’t be perfect, but it’ll be better than the way it looks currently! I’ve managed to remove the silver pen marks with plastic polish.
As for the internals- they actually seem fairly decent to me. I tested the big caps C1 and C2 and they only had a leakage or 1.3mA at their working voltage of 63V- which seems quite ok, but I think I’ll replace them with Chemicon 200V / 22000uF caps.
As per usual I’ll replace all the electrolytics- and I’ll go about testing all the foil capacitors and resistors to ensure they’re in tolerance.
Otherwise it looks like its been set up for 100V use, for some reason the fuse holder has been bypassed (not ideal) but it does have a fuse hard wired to the transformer. Either way I’ll replace the fuse holder to bring it back to spec and i'll rewire it to 240v to suit my part of the world.
It also looks like the flyback diode mod has been done which is good news- and perhaps some other mods too.
