Hi!
I'm new here :yes:
http://www.audiokarma.org/forums/showthread.php?t=427288
This is my first post, forgive my basic english, I'll use google translator
I have only basic knowledge of electronics, but enough to make a typical maintenance on this device.
I found it near the trash. When turned on, it worked almost perfect, with the typical noise of the "knobs" and after 5 minutes began a noise typical of capacitors, so I started to change.
I checked some diodes and transistors, all apparently work well.
Unfortunately, my inexperience and my lack of concentration I made a mistake. I changed all the capacitors of the power supply and amplifiers, noticing that all were in their position. In turn, exploded lol. My mistake, a capacitor of 10000uF 35v plugged it backwards :cry: The result, a capacitor burst, and a rectifier dead.
My second error, improperly connected cable, resulting in a transistor (H801) died.
(I know I was stupid, I need not say it haha)
OK,
- I changed the two 10000uF 35v capacitors, for new (50v 10000uF).
- H801 transistor changed for a new one.
- I changed the rectifier with a new one. The original was 6 amps and placed one of 1000v 8 amps.
My third mistake, broke the diode H005, I changed with two diodes 4148, as I found in this link: http://www.audiokarma.org/forums/showthread.php?t=373582
Now on!!
(almost happy)
Calibrate the bias of the P700 and P800, all perfect values. Noise no longer exists
But still I have a couple of problems. :tears:
At first everything looked fine until I went up the volume :thumbsdn: is an overload and the lights go down in intensity. The sound is perfect, but a very low noise in the background, which sounds for any of the 4 outputs (in 2x40 and 4x17 as well).
(see the video)
http://youtu.be/YUypipyJoCs
If the load increases, raising the volume, connecting the decoder (sqa-2b) and put the FM radio, I can not go much volume because the source is not able to maintain the signal and the sound becomes noise and voltage to the speakers, the lights go out. It seems that AC pass. Apparently the decoder is not good, do not know, for now I will not use.
I disconnected the two amplifiers (P800) and capacitor voltage is 35v (in the rectifier), but when connected, the voltage is 52v (in the rectifier) Is this normal?
By spending 5 minutes in the power supply components R805 and R809 are heated much. The H801 is heated too. (C, B and A in the picture)
I checked all the transistors and diodes of the P800 and P700, apparently they are all OK. I checked all connections and are all ok.
I do not know what to do: '(
What else I can check?
I'm new here :yes:
OK,
Now on!!
(almost happy)Calibrate the bias of the P700 and P800, all perfect values. Noise no longer exists
(see the video)
