Inherited this table. Hasn't been used in a while but seems to work well in a start up test. I see lots of threads on the 6100.
Just looking for opinions on the table being a keeper and the ADC ZLM cartridge?
).Competent belt drive turn table that has a cult following for its aesthetic.
The ADC ZLM cartridge was a top performer highly priced for the fine stylus tip - (high compliance).
The original ZLM stylus has the "ADC ZLM" label on the name plate.Over my head on that ear4. Are you saying it will work fine with the PL50 arm even though it's not a low mass tone arm. It does have an orig headshell which appears to be a lightweight. Also, not sure if it needs the stylus replaced or not.
I don't know the threshold for a low mass, med mass and high mass tonearm. I've played a ZLM cartridge on a Yamaha turntable and a Dual with excellent results but I don't know the mass of those tonearms and how they compare to the PL50 or 6100. I know a heavy (8 grams or more) ultra high compliance (40 to 50cu) cartridge sounds terrible with my turntables. But the ZLM is fairly light and not as compliant as the 40-50cu so it should work with a wider range of tonearms.It's as pictured, original stylus. Haven't played it yet but this came from a friend and I know it was stored in a closet for something like 20years or more and not used much before that. I'll work it over to the bench and check it out. Was thinking of moving the cartridge over to the PL50 with the thinking it would be a better match.
Table performs all functions well despite no service in a very long time,grease is still soft and not hardened. Should I clean an lube anyway or go with it?
The cartridge is set a 1 1/2 grams, plays with no noticeable distortion. Table had a ground hum with the ground wire connected which stopped when I connected it.
But it has a low volume "moan" when the stylus is on the record, it's there all the time but most noticable on blank space. Moan stops when stylus is raised off the record.
Cartridge or table problem?
