Marantz M2 bookshelf, worth refoam?
tin_ear
I had forgotten about these til I stumbled over them in storage. Real walnut, fairly heavy well-built two-ways with a 5-1/2 driver and a 1" dome tweet. The foams are gone and may be difficult to find. Anyone think they would be worth refoaming? Sorry but this is the only pic I have at the moment.
Try Rick Cobb (looneytune2001) on eBay. No affiliation, just a many-times-over satisfied customer. He probably has the foams you're looking for - or he can at least find a very, very close match if he asks you for measurements and details.
IMHO, the wood grain and the weight make refoaming a worthwhile effort. Put new surrounds on them and see how they sound. With a little oil, you know that the wood will look good. Even if they don't end up sounding great, they will still look impressive.
Regards,
D-Ray
Those should sound nice.I have a set of the Marantz M16.They rock out.Big Tuna has a set of the M10's,maybe he will chime in.Here's a picture of the M16's
ry%3D400
hehehe here I am! :D Yep, the M series Marantz's are kinda rare and deserve to be kept intact as long as they are not tore up. Refoam them! :) BTW, they are 8 inch woofers with a dome cell type tweeter, not the LPF dome like my M10's and elduce's monster M16's. I love my M10's, they are awesome, and they project a soundstage of purity, detail and clarity that even surpasses that of their bigger siblings, the HD880, DS920, DS940 and HD88. The only comparable ones are elduce's M16's :D M16 is a very appropriate model # since there is a machine gun called M-16, heheheh!
Well I finally got a minute to snap some pics.
These are 5-1/2 drivers. They really are heavily built and the veneer wraps around the rounded corners, giving the feeling of true quality workmanship.
These are "focused field" units, now that's impressive, eh?
I really do think that these will sound really good, I just wanted to find out if they were duds before I put effort/dollars into them.
[/IMG]
As you can see, they don't have the conventional dust covers, but the full concave piece glued into the cone. Now, if I want to re-foam the 'right way' (using voice coil shims) how do I remove the dust cover to do so?
If you want to do it the right way, do it by touch. Just gently give the cone a full excursion after you have glued the outer rings. Keep going around at 60-90 degree angles to make sure you have a clear path all around, then press the glue together. Then go around again with shorter excursions just to double-check. I'm probably telling you something you already know with all of the above instructions, but I sure wouldn't want to try to replace inverted dust caps.
By the way, those are some meaty looking magnets on those drivers. That and the real wood veneer make those look like a keeper.
Regards,
D-Ray
I think you have a winner. Along with the Imps and the HD/DSs, the Ms are the other series of highly regarded Marantz speakers. Has anyone here even heard of these little guys before?
Yep :) The M Series were Ed May's last line before his untimely death in 1980. Marantz did have an "M" series in the very early 70's, but those were a spin-off from the Imperial Series, and the M was suffixed after the number. The M's I'm referring to were only made in 1980 and the letter is prefixed before the number. The M2/10/16 took over after production of the HD/DS ceased in 1980. The production run of the M2/10/16 was so short because Ed died that same year, and upon his death, production ceased, making them perhaps the rarest Marantz speakers made. My M10's I found were a complete stroke of pure luck. I had intended to use them for parts, but upon seeing them, all they needed were surrounds and a good scrubbing. Upon finding out how rare these were, I just could not bring myself to scrap them. Once I listened to them, that made it even more apparent to leave them be. They project a huge soundstage with beautiful/dynamic imaging due to them being mirrored. They are on a VERY short list of my favorite speakers of all time.
But hows the attack on the M-16's....? :D
If you played an actual M16 machine gun soundtrack through the M-16's, it would make you literally piss your pants, and probably scare the hell outta everybody in your neighborhood to the point of them calling the cops. You'll have to ask elduce for input on how they sound. he is the only known AKer with M16's. The woofer magnets in the M10/16's 12 inchers is much larger than it's HD/DS siblings, except for the first generation HD's(77 & 88) which are equally impressive.
Just picked up a pair, sans original woofers.
Absolutely nothing on these to be found anywhere.
Would love to get a set of originals, or even part number for the drivers, tho clearly a long shot.
Even with these bass speakers (from Philippines), sound is very nice.
