David_NC
I have three of these monoblock amps, and apparently this model has known capacitor issues. I can handle finding replacements of the small caps, but there are two 10KuF / 71V filter caps in each amp labeled C801 and C802 that are bulging, and a couple are almost splitting at the top. The issue is their size. I need them to be no more than 2" tall, which is the easy part; the fact that the diameter needs to be 1.2" / 30mm is the hard part.
I have looked on Digikey and Mouser, and caps that narrow that are anywhere near that voltage. The closest is a Cornell Dubilier (https://www.mouser.com/ProductDetai.../380LX103M080A052?qs=9nXXK2icEIzReJqzT8H3GA==) that's 35mm wide. That might work, if there was only one, but there are two side by side. I'll have to measure to verify, but I don't think this will work.
I'm curious as to what others have used in these amps, as they seem to be known for having bad caps from the factory. Some things I've read said that the smaller caps often bulge and leak after 4-5 years due to being underspec for voltage. The small caps in mine look OK, but I haven't done more than a quick look-see. Perhaps the small caps have been replaced, since they are now significantly older than 5 years.
Any ideas, tips, or insight into these amps is appreciated.
These are nice little amps - 125WPC @ 8 ohms, 180 @ 4, and two can be bridged for more power. Here they are before cleanup; I don't recall one having a chip on the front, so that must be something on it.
