I just scored an early (S/N < 3000) champagne faceplate Model 33 I will restore! The 1060 I did last summer opened up my apetite for this.
Right now, the unit seems to have all original parts, but it was converted to 220V operation. It’s in decent shape cosmetic-wise, but it will require new screws, feet (didn’t have any, but it didn’t have the woodcase either) and new knobs (these are not original I’m afraid)
It sounds pretty good, but not as detailed as my restored 1060, unless I EQ in some +4dB on the treble side. It’s also quite noisy, having a constant hiss that the 1060 doesn’t have - sounds a bit like surface noise on vinyl I guess
I’m really on the fence regarding the poweramp - I’d go with a 16 for the dual mono construction, but I feel it’s way too powerful for my current setup and I’ve also seen a 32 available. What would you guys get?
Last but not least, I’d look to get a replacement for the volume slider. It’s working ok now, but it has quite a bit of side-to-side play and I know they’re very rare, so I’d be sleeping better knowing I have a replacement at hand. Do you know of a good source for such parts, outside of a donor unit?
