Hello everybody
Looking for help in replacing caps for the large can. For this task I was given three nichicons (65uf, 500v) by a friend who refurbishes these amps. I disconnected the leads to the can and soldered the new caps in place mounting them in under the chassis, The schematic for the can shows values of 40, 40, 20uf at 500v. First listen reveals thin bass and bright midrange. Finding this unpleasant, I reconnected everything to its original state and removed the nichicons.
My Question is this: What should the values for the replacement caps be? Also would like to hear opinions for type and brand. I'm not an electronics expert by any means but I'm thoroughly competent with this type of work as long as I'm getting advice.
The large can is C16 on the schematic.
