ivo
Well-Known Member
Hi guys! Is anybody here with experience with Marantz SR940 Stereo Receiver? There is NO service manual or schematic on the internet. Shortly:
*There is no output sound
*The speaker relays click (there are two relays for A and B speakers terminals)
*I plugged it into a Tone generator(1000hz, 0db) . The receiver input is CD input. I measured this signal with an oscilloscope and I got a wave signal out of the speakers. This signal is not changed when the volume control of the receiver is depressed up and down.
*The signal is measured at the same amplitude at the flat cable going to the Transistors Output board and on the speakers terminal and it's independent of the Volume control.
*Also I measured with Ohm meter the C and E of the output transistor(onboard) and there is NO short signal. The Outputs are 2sc3182. Actually, there is no short signal between any legs.
So my suggestion is that the problem is in the Preamp section. But without schematic...
There is a Toshiba TC9151 HIGH-VOLTAGE, AUTO-ZEROED OPERATIONAL AMPLIFIER(24 pin dip) in the Preamp section, that maybe is the problem...
I may go and do a blind replacement with this integrated circuit.
Any help or idea?
Thanks!!!
Any help or idea?
Thanks!!!
