MC2125 Help
Greg Wright
Hello all. Looking for advice on my MC2125 amp. At lower to moderate volume the right channel meter displays a much higher output than the left channel when set to Watts mode. Power guard will occasionally flicker. The sound itself is fine. No distortion. Very puzzled by this.
Any advice and help is appreciated.
Thanks-
Welcome on AK and MCINTOSH forum
1) what is the left and right indications when amplifier is off ?
2) same question but amplifier on with no modulation at the both inputs
3) are you sure that level who come in is 100% identical on left and right channel ?
4) are meters indications identical (left and right) to any position of the switch ? don't forget to decrease level at the input for -10 and -20 dB positions
Thanks for the reply. In answer to your questions:
1. In the off position the meters are at -0012.
2. In the on position with no volume the left meter is moving slightly at the -0012 level. The right channel is bouncing between -1.2 and 1.2.
3. Both levels seem consistent.
4. In the -10 and -20db settings the meters are at -0012. Same as at the 0db setting.
