McIntosh 2500 power amp in KC Craig's List
If a member is located around Kansas City, that may be a score.
File Photo:
Specs:
Power Output:
Stereo: 500 Watts per channel
Mono: 1000 Watts
Output Load Impedance:
Stereo: 1 ohm, 2 ohms, 4 ohms, and 8 ohms
Mono-Parallel: 0.5 ohm, 1 ohm, 2 ohms, and 4 ohms
Mono-Bridged: 2 ohms, 4 ohms, 8 ohms, or 16 ohms
Rated Power Band:
20Hz to 20kHz
Total Harmonic Distortion:
Stereo: 0.02% max up to 500 watts per channel, both channels operating
Mono: 0.02% max up to 1000 watts
Intermodulation Distortion:
Stereo: 0.02% max if instantaneous peak power output is 1000 watts or less per channel
Mono: 0.02% max if instantaneous peak power output is 2000 watts or less
Frequency Response
20Hz to 20kHz + 0 - 0.25 dB
10Hz to 100kHz +0.25 – 1 dB
Noise & Hum
95 db below rated output
Damping Factor
Greater than 30
Input Impedance
50k ohms
Input Sensitivity:
Switchable: .075 volt or 2.5 volts – Level control provided for higher input voltages
Power Guard:
THD not to exceed 2% with up to 20 dB overdrive at 1 kHz
Power Requirements:
120V 50/60 Hz
Dimensions:
19”w x 10.5”h x 17”d, 129 lbs (net)
No affiliation.
Yeah these are now going for over 2000 dollars, but the black faced units usually go for more than the silver faced ones. Don't know how good these amps are for good tight bass as it has a pretty low damping factor.
Let me assure you the 2500's have plenty of bass;and it's good tight bass at that. I also thought that a high damping factor meant good bass; but living with a 2500 has caused me to think of df to be a meaningless spec.
Anyone grab that big mac yet?
One thing I'll say for Macs, they hit their ratings.
If this says 500 watts, that's 500 watts for sure.
I used to have a 2200 for the bass bins of a rental PA.
The 2500 replaced it. I loved everything about it except picking it up.
