AA6U
I'm working on a McIntosh MC60 (model with the neon bulbs for voltage regulation) that is putting out a short, low pulse every 4-5 seconds. It has been completely rebuilt and worked great until one of these events caused it to start pulsing (not sure which):
Event One- One of the 5U4 tubes shorted and blew the fuse. After both were replaced, the owner thinks the pulse may have started.
Event Two- The owner switched out the 6550 output tubes and he installed one without the pin locator on the bottom of the tube incorrectly and blew the 220 ohm 1W screen resistor for that tube as well as the fuse. I replaced that resistor and tested all of the components around both output tubes and they test fine as well as the other resistors.
During a pulse, the neon lights voltage regulators go completely dark but come back on quickly. Also, the grid bias voltage jumps around and the B+ voltage jumps a little during a pulse.
With no audio input and the output tubes installed, the pulse sounds like a soft bump in the speaker. With audio playing, the volume decreases moderately for a split second during the pulse.
The pulse occurs with or without output tubes installed, with a dummy load or a speaker connected to the output, and with or without the 12AU7, 12BH7 or second 12AX7 installed. I have checked all of the filter caps and they seem to be fine, short of replacing them all. The output transformer measures the correct ohms.
I installed a different set of tested driver tubes, and it behaved the same.
As a possible solution, I replaced C4, the filter capacitor in the voltage regulator circuit, and C5, the bias filter capacitor, but neither solved the problem. I've also checked various resistors and everything seems to be in spec.
The audio sounds great. It's just that it pulses every 4-5 seconds. I've asked some of my tech friends and they are perplexed also.
Does anyone have any thoughts or suggestions on what's causing this and how to solve it?
