Mcintosh MCD301 Repair
sys.entropy
I purchased a used MCD301 at quite a deal because the top trim and cover had some pretty big scratches in them. Upon receipt, everything powered up, ran fine for a day or two, then the disc tray stopped coming out smoothly, then stopped working almost entirely. Now, this being a buyer beware world, I hold no ill will against the seller. In all likelihood, this issue just started when I received the unit. So, after a little research, and some thought, I determined that the problem was the belts.
Since I really didn't feel like having my new toy out for repair for weeks or longer, and didn't really like shelling out any more cash to anyone (just finished building my first real two channel system), I decided to take on the repair myself. After a quick call to Mcintosh, I had a new set of belts on order as well as a new trim piece and a new top cover.
Since I had some difficulty getting any information online on this repair, I figured I'd share it here.
Here is the top of the MCD301, there are eight (8) screws holding the top cover, six (6) on top, and two (2) on the rear. No real trick to removing the top cover.
Removing the top cover reveals the transport, PCBs, etc.. Yes, the transport is stamped Denon, yes, it's based on a Denon production transport. I am not going to get into the debate of is it a special Mc transport or a standard Denon transport. But, I will say that there is a Denon service manual has a breakdown that is identical to the transport found in the MCD301. Having the breakdown helped. There are only six (6) screws holding the transport cover down. They are located on three sides of the transport, the fourth side is held on by tabs. This means, to remove the cover, you have to slightly lift one side, and then pull the cover to the right to remove. Be careful removing the cable hold downs.
Once the transport cover is removed, we easily see the inner workings of the transport. This is where I pulled the unit, powered up, and pressed the open/close button. With a little manual help, the tray did open, revealing the belt assembly.
It is necessary to remove the large pulley to replace the belt. There is nothing complicated about this. The large pulley is retained by a very small snap ring. This pops off with a fine flat screwdriver. The smaller pulley is held in with a unique disc with a slit in it. This disc has to be removed to to get to the belt. This is also easily removed with a little finesse. Be careful when removing. I got the feeling that this plastic disc could be brittle and won't give too much. Just flex the disc enough to pop one edge out of the groove on the pulley shaft, rotate the disc, and it will spiral off easily.
So, with both belts free. It was easy to replace the secondary (on the left) belt. To replace the primary (right) belt I needed to remove the motor assembly. No big trick to this either. There are three fixed position screws holding the motor to the transport chassis.
Pop the motor off, swap the belt, and do everything in reverse. All in all, not knowing what I was doing, the whole job took about 45 minutes. I could probably do it in 30 now. The design allows belt service to be pretty easy. With the transport back together, I replaced the trim piece and put the new cover on, and we're back to mint!
While it may be intimidating to tear into a piece of electronic equipment costing several thousand dollars, with plenty of research, I felt this was a pretty straightforward repair. Just go slow, be careful, look at everything twice before taking anything apart.
-John
Hello. Where did you bought the MCD301 belt kit? I just bought MCD301 used and the cd tray is not in perfect shape. My technician is needing the original belt kit to replace but i don't know where i can buy this. Its impossible to send to Mcintosh to get repair. Thank you.
Did you have to send your player to them? Im needing this part but im from brazil and i cant send to official repair. I have on address in nyc to receive the parts.. Do you think i can get this with them? Can you send me you contact when you bought these belts? Thank you.
PM sent.
Question for you, is the voltage selection board on the lower left corner of the front of the unit? I'd like to get one of these local to me, but may need to change voltage. My other units are not an issue, and I don't think this one is either, I've seen photos from ones in Australia where it's just in a different position, but none are clear enough to see.
I just picked up a 301 can you provide parts information please, my transp
ort is acting crazy, belts are way loose. Thanks
-John
I had this problem after my MCD-300 sat in storage for several years. I contacted McIntosh and get the new belts and they worked for a couple of years. The belts they sent were actually square cross-section O-rings, 2” ID, with 3/32” x 3/32” body. When the cd drawer started to drag in and out again I opened the transport mechanism again and found the belt at the back, which powers the drawer in and out, was slipping, as was the belt at the front, which raises or lowers the drive mechanism, was slipping as well. I went to the Grainger website and ordered the 3/32” square O-rings (package of 25) but with an ID of 1-13/16”. These shorter belts fit snugly around the pulleys on the drawer mechanism as well as the transport raise/lower mechanism with no slippage. The drawer works quickly and smoothly now, and the laser assembly raises to meet the disc without any hesitation. Plus, since you have to buy 25 of the O-rings I have spares should they start to slip again. The O-rings are $20.72 for a package of 25, Grainger part number 723W14.
