BlackSoldier
Hi guys..
I just have a question for you all. I have the above mentioned little tube amp and i am looking to change the tubes in it. I found out that one of my Mullard EL84 tubes was bad a while back but just put the amp in the closet and used something else. Now i want to start using it again because I miss the tube sound. It presently has 2 Tung Sol 12AX7's, and 4 Mullard EL84 tubes. What would be some good replacement for these that are not expensive but has good quality sound? Thanks for all your kind help.
BS
PS, I was looking at some JJ 12AX7 and EL84's. Would these work?
BS
