Mission 765i for tube amp?
70GTO
shopping for speakers for fisher x202b unit. these are 93db sensitivity, wide range of power . I mainly listen to records 70/80 rock. Was advised to find vintage speakers, these where available for $150. also has RTR series 4 and Advent legacy 2 but the missions seemed higher end. thoughts.
For some reason 94db/w/m sticks in my head and tubes work well with this kind of number. Good speakers to boot.
I have a X-202B and for years used it to drive a pair of fairly inefficient Kef 103.2. That amp has a lot of power, we are not talking about a mini tube amp with only a few watts of output.
The Mission are efficient. I found them a bit bright and forward when I was selling them, they may actually be a great match with the Fisher. Mission tended to go for dynamics and attack over real low bass, even in these bigger speakers which were a replacement for the final series of Mission 780. Give them a listen with your music, if you like the sound they will be good for your use with your amp.
Other ones I would consider would be the Klipsch KG series from that era, maybe KG4. Another good choice with a different signature would be JBL L60T or L80T. Happy hunting.
Please read my post again, I said I found them, the 765, a bit bright and forward when I was selling them. We had speakers from PSB, Kef and others that were smoother than that generation of Mission. I also said they should do well with tubes.
Out of curiosity, did you ever spend much time with the last generation of 770 and 780, the ones with the semi horn loaded tweeters, stepped baffles and two recessed grooves around the front of the cabinet? Those did not sound anything like most other UK speakers so I would personally not generalize and say since Mission are British they all sound a certain way. I found those 770s rather nasty and I read a review of the 780, in a UK magazine, which was perhaps the most negative review I have ever seen on a speaker in that price range. It was backed up by measurements and I did not really disagree. They were replaced by the 764 and 765 IIRC which were better but I would recommend giving them a good listen, as with any potential speaker purchase, and drawing your own conclusions.
The recommendation for Klipsch, and JBL, was based on the type of music mentioned in the original post in case the Mission did not appeal. I had plenty of customer who listened to rock and rejected Missions outright as not having the type of sound they were looking for. They often preferred the Klipsch or JBL so I am passing that on.
I am not saying anything is good or bad, just making suggestions as to what to listen to and explaining what the differences might be based on thousands of hours of working with dozens of models from each company. As always, the listener should pick for themselves.
Thanks again, I have jbl t-80 from 1988, bought new that I use with my SS accuphase. But I wanted to set up tube amp with separate set of speakers.
Glad to help. Funny, I had missed the L80 in your signature when I recommended them. I guess I was not too far off the mark.
Great avatar, do you own one?
I have Mission 765i and very happy with them for well over a dacade or longer. Sounded great when I had my McIntosh 2105 and C-28 Pre, very nice with my Dynakit ST70 and Dynaco PAS3 Pre. Now they are hooked up with my Denon PMA-860 and still very happy. Sounds much nicer than my old Heresy speakers.
Opus
Update. Wood on bottom of one is water damaged. Swelled up about 12 inches up and slightly warped. Very dusty components but no cracks in speakers. The water damage is concerning. Internals could be effected with patina. Passed for now.
I know this is late, but I believe the 765's were geared towards classical music, not sure where I read that, but it sticks in my head. For what it's worth to anyone reading this to find out about the 765, I don't find mine to be too bright at all and possessing quite decent bass considering the size of the drivers.
I'm currently running them in rotation with Monitor Audio MA-2's (more bass but muddier) and Polk SDAII's which are very close in sound to the Missions.
My amp is a Marantz 2215, so not possessing a lot of power, but very able to deafen the neighbours with the Missions (and the others too), so good speakers if you can find a pair in good condition.
