Monteverdi H330 dial lamps?
Hemingray
Vintage Geek
Trashpicked this two weeks ago. After replacing four 100 ohm fusible resistors in the output section, she sings beautifully. Only issue left is ALL 8 of it's dial lamps are dead. These are odd little festoon lamps with just soldered wires on each end. Measured 6v at those points. Question is, what kind of lamps are these and where do I source replacements? I tried white LEDs but they don't provide the best light on the dial.
Can't help with what your asking but I had a Monteverdi as my first stereo.Bought it mail order from Speigal if you remember them.Not to minimize what you have but they were all in ones.Is that what you have?
Bulb in question. No base caps at all, just wires. Pictured is the stereo with some white LEDs installed. Not too fond of how blotchy the light pattern is with those.
That is what is known as an axial lamp. Should be able to get suitable replacements through AK member dgwojo - drop him a PM.
John
